- south yorkshire
- Dave
- Yorkshire
Stripe be gone
Just lots of cut and polish now, but happy, think it looks so much cleaner
yes ot does look swolllen, and there also looks to be some cupping on the inner edge blocksafter looking at the picture it looks like it's swollen if it is I think you need new tyre If the cut hasn't gone through to the casting it should be okay
If the damage is on the inside of each, it is probably down to camber, or the tyres have been rubbing. Check in the wheel arches to see if there are any tell tale marks. I agree if the cut is not deep, no need to worry about it.Took the rear wheel off to check my rear brakes and spotted this!! Bl**dy marvellous.... I am aware that there will be some wear on the inner edge due to the camber but this split Im a little concerned about and also some random marks on the tyre!
Any ideas from you guys if you think this is okay?
Im pretty sure this was probably done whilst in Spain driving through the mountains last year so Im hoping its only a small slit from a sharp stone but any advice would be greatly appreciated!
(Edit: just realised I didn't take the 19" rims to Spain)!
View attachment 103978View attachment 103979View attachment 103980View attachment 103981View attachment 103982View attachment 103983View attachment 103984View attachment 103986
No tyre expert but I personally wouldn't trust it, sorry budJust did a video to hopefully show the area better to you guys. The tyre does not look swollen to me maybe looks worse in the pictures.
I read if the cut is not below the tread depth it should be okay.I'll keep an eye on it me!
Looks loads better buddy!![]()
Some Rider side skirts would look nice!![]()
I think it’s just the shiny wear marks that make it look swollen in the picturesJust did a video to hopefully show the area better to you guys. The tyre does not look swollen to me maybe looks worse in the pictures.
Cupping could be due to my wheels being slightly buckled, I had them repaired a while ago but they have never been perfectly round!
you only got a handprint size of rubber between you and a bad experience if the wheels aint true thay need fixing or scrapping as out of ballence or out of round will put undue strain on other suspension bushes and even diff parts ....i would get camber correct and get replacement wheels. and tyres...may not look as nice but safetey is paramout in my viewI think it’s just the shiny wear marks that make it look swollen in the pictures
Apart from the wear and a couple of scuffs( you been booting it mate) looks ok
so its fine to have buckled wheels ....and the future damage they may cause to other partsNothing wrong with @Richard Fox ’s wheels mate, he’s just questioning the small cut in the tyre
As for negative camber , it’s not actually as bad as you think, racing drivers , track day drivers etc actually crave it as it prolongs tyre life under those situations ( hard cornering with neutral camber can actually be dangerous)
Now I know we don’t drive under those conditions but it’s wrong to assume that negative camber is a danger , the inner wear on the tyre is usually as much down to toe adjustment as it is to camber ( this also gets knocked out when lowering) slightly more pressure in a tyre can help with this ( not too much of course)
No disrespect but I must have missed something, where’s the buckled wheels ?so its fine to have buckled wheels ....and the future damage they may cause to other parts
the last post with video...quote cupping could be due to slightley buckled wheels ..not fully roundNo disrespect but I must have missed something, where’s the buckled wheels ?
Ahh , now I’m with you and yes if wheels are buckled then they need to be repaired or scrapped I think the statement above is an assumption rather than fact but I now see what you meanthe last post with video...quote cupping could be due to slightley buckled wheels ..not fully round
Just re read Richard’s post especially this bitAhh , now I’m with you and yes if wheels are buckled then they need to be repaired or scrapped I think the statement above is an assumption rather than fact but I now see what you mean
i agree but even a slight buckle would transmit movement or pressure on bearings either wheel or half shaft and inner workings of diff or rack,,or just ruin oil seals etc,,,,it may not be felt due to the rubber bushes but will be there ...just an engineers point of viewJust re read Richard’s post especially this bit
I would assume they balanced ok if they were repaired which is acceptable
If out of true and won’t balance then that would be different
i would take them back to repairer with instructions to make them fully round and running truei agree but even a slight buckle would transmit movement or pressure on bearings either wheel or half shaft and inner workings of diff or rack,,or just ruin oil seals etc,,,,it may not be felt due to the rubber bushes but will be there ...just an engineers point of view
