Had a busy weekend! Replaced the PCV valve & relocated it in an accessible area in the engine bay, fitted an oil catch can, upgraded the spark plugs, loctite'd the swirl flap valves, cleaned the upper & lower plenums & throttle body, replaced the gaskets, put it back together and went for a run to Cleggy.
I bit the bullet and exceeded my comfort zone by addressing the smoking issue I'd had on my S1 3.5 as it was doing my head in. The engine ran absolutely fine but it had been smoking badly, so by a process of elimination (head gasket test, fluid monitoring, LPG isolation, valve saver isolated) I came to the conclusion that it was the PVC Valve.
I followed the 'How To Guides' on the forum which were very helpful and thanks to the contributors, the removal of the plenums was tricky for me and took longer than I thought (fat hands and lack of correct tools) but eventually I did it. My PCVV was clogged open and the plenums were really oily and needed a good clean, I was relieved to find the fault with the PCVV as it justified the strip down!
A few cuts and grazes later I had it all put back together with the new PCVV located next to the OCC in the engine bay in case I needed to change again.
I went on a blast down the M180 to Cleethorpes and have noticed an improvement in the smoke since, I'll need to monitor it over the next few weeks but fingers crossed we are sorted.
