- south yorkshire
- Dave
- Yorkshire
Excellent behaviour-Expected to be using my black one to tow the boat to the river just to give the boat a run and test before taking it on the sea on Firday. Pulled up tonyhe boat, dam I'd left the 13pin to 7pin towing adapter in the caravan. Phoned around local car shops, do you have a 13 pin to 7pin adapter? No. Went to the caravan to get the adapter, a bit late for going boating by the time we got back. Went shooting with my son instead. Black one is running ok again with the used replacement alternator from the scrap engine in the yard.
Happy to help, you have helped me on multiple occasions so it's the least I could do!With thanks to @Tino and @AlanM I am in possession of a new front wheel bearing saving around 70€ in shipping and duty. So, today I began the replacement process. The knuckle/hub came off without too much bother. The ABS sensor was stuck fast as I suspected so I unplugged it from the loom and removed it all along with the hub. Still, even with it on the bench, there was no way it was coming out without mullering it and even with a blowtorch it put up resistance, so I'll be needing a new one of those too.
The bearing was a complete swine to remove from the knuckle having had 23 years to seat itself in. Further use of the blowtorch and a session with a mallet followed by a six ton press and finally it let go with a bang and by this time it was split into its two halves.
Tomorrow I will reassemble it all other than the ABS sensor. Originals seem ludicrously expensive so I've ordered a cheapy from Hong Kong and we will see what happens. I'll be driving around with warning lights until it arrives.
Glad you sorted it mate.Finished fitting the bearing and went for a test drive. The rumbling in left hand bends has gone but there's another road speed noise which I thought might be due to the bearing also. Could be a tyre so I'll have to do a swap round. Keeps bleating ABS and 4WD error so will be glad to see the new wheel sensor.
Is that a euphemismGlad you sorted it mate.
Give your donut a good pull, maybe some movement in that
Not this time lolIs that a euphemism
That's true on mine. It's had a plug in mile converter chip so it averages (on the display) around 5km/L but that's actually 5 miles per litre, so whilst bad, not as bad as it looks.If the trip meter is reading in miles. Then the computer output fuel economy system is probably also miles so not km/l but m/l so your economy is probably not as bad as you think
The best brake fluid I have used is ATE TYP200 and can be purchased from eBay.Incidentally a couple of minor hiccups from the driving this week.
I'm pretty sure I boiled my brake fluid on the very steep hills coming into Lyme Regis yesterday. Discs and pads are only c. 500 miles old all round so it's not those. What spec of brake fluid is best for the E51?
Also noticed some odd behaviour from the aircon on long drives - after a couple of hours driving, the air pressure coming out of the vents drops to pretty much nothing. What little air that comes out is still cool, but the flow rate is next to zero so not enough to keep the car cool. After stopping for a bit (like a lunch stop at the services) the aircon works normally again - for a while at least. Blower motor sounds like it's working the whole time even when the flow rate is low. Any ideas?
