- Bentwaters
- Julian
- East Anglia
Reckon the labour will be expensive tho.
What is the first thing folks notice when the cats go?
It's unlikely that would fit between the exhaust manifold and front cats, if it could be done I reckon a completely different exhaust would need to be fitted to make it fit anyway.
Would think labour ad parts would be expensive.Reckon the labour will be expensive tho.
I just did out of curiosity as to how long it would take to look through 11 pages, roughly 2 min.Sorry not reading 11 pages to find out if E52 2011 3.5 is actually related to this topic or not
I don't think it is from what I've read, or it's certainly much less common.Sorry not reading 11 pages to find out if E52 2011 3.5 is actually related to this topic or not
Thank you I'll add that to my to do list, I take most people just get a section of pipe welded where the rear cat was? Or can you knock out the interalsI've not heard of any E52s suffering in the same way. However this may be because
a. there's far fewer E52s in the UK
b. those that have been imported are much younger than most E51s here.
As I see it any system where there are two cats in line will be susceptible. RAC/AA put a life expectancy on cats off 100k miles or 10 years. The front one does the vast majority of the work and will therefore break up first. The rear one will most likely then get blocked by the debris from the front one.
If I had an E52 I would look to safeguard it by dealing with the rear cats before any problems arise. Others may well accept the risk and have many happy years of cat-trouble free motoring.
On the E51 you can either take the cat out completely or just decore it. Assume 52s the same.Thank you I'll add that to my to do list, I take most people just get a section of pipe welded where the rear cat was? Or can you knock out the interals
Good workHaving 're read this entire thread ( https://forum.elgrandoc.uk/threads/...and-the-do-not-remove-rear-cats-debate.18398/ ) again this morning here are my conclusions and the options available of which there are at least half a dozen. Rough costs are an estimate on people's postings throughout the forum. So please dont abuse me if some are slightly inaccurate!!! No agenda as I don't even own an e51 so completely impartial take on the matter.
Option 1.
Remove/decore the rear cats. Cost £100
Pros- cheap and easy. Van down time = a couple of hours.
Cons- not a 100% safe fix, and could still have future problems from front cats blocking themselves.
Option 2.
Remove/decore the front cats leaving the rears. Cost £400
Pros- eliminates chance of cat break down and blockage. Still a reasonable price.
Cons- more difficult to do, greater difficulty finding someone to carry out the work. Emissions feed back unknown. Van down time = 1 day
Option 3.
Remove/decore both front and rear cats and replace with aftermarket cats down stream. Cost £900
Pros- completely eliminates risk of old cats disintegrating. Healthy emmisions.
Cons- more expensive, very, very slim chance aftermarket cat could disintegrate in future. Van down time = 1 day.
Option 4.
Complete new stainless exhaust system with aftermarket cats. Cost £ 1200-1700
Pros- removes risk of original cat disintegration, sound lovely will last a long time.
Cons- more expensive. Very, very slim chance of cat failure. Van down time = 1 day
Option 5.
Lpg install. With full cat removal. Cost £2000+
Pros- eliminates any possibility of cat failure, cheaper fuel for future use. No emission worries at MOT as tested on lpg not petrol.
Cons- more expensive process, future lpg servicing costs, not all systems/setups are perfect causing possibility of other mechanical issues. Van down time = 3/4 days. Plus delivery/accommodation costs during process.
Option 6.
Carry on as you are with whatever process you've already done or not done.
Pros- live in a world of bliss and worry about what if's later. And enjoy life and your Elgrand.
Cons- your car could (But might not) breakdown at any moment. Expensive repair bill (£2.5k) or scrap value only.
Do with this what you will. The info is out there for anyone to read and make an informed decision on how, why, or what you want to do to extend the life of an Elgrand.
Don't think this discussion will ever go away, so long as people are still buying elgrands and not doing their homework on them.
My fronts are decorred, gone through 2 mots now without issueIf you get the front cats recored does it cause an issue with the emissions sensor which is just after one of the front cats? Option 2 is my preferred choice but concerned it will throw up fault codes
That's good to know I was wondering about that as well. So it doesn't throw up any emissions faults in the car itself?My fronts are decorred, gone through 2 mots now without issue
Lots have reported no issues but some have had emissions problems after front decore , hard to tell without lots of evidence but could be down to a combination of of thingsIf you get the front cats recored does it cause an issue with the emissions sensor which is just after one of the front cats? Option 2 is my preferred choice but concerned it will throw up fault codes
From what I recall, the E52 is not affected by the catalytic converter failure problems of E51sWhere can we buy decat for e52 in UK?
