E51 Series 1 (2002 - 2004)...... let's see em
Maybe we could have some kind of OC pilgrimage to you and finally get her fixed. What was the cause of the bottom end failure?
After a year of cleaning every nut and bolt which was removed, polished and new timing chains fitted with god knows how many new seals etc I then discovered it still knocking from the bottom end! I pretty certain its spun a bearing shell as its sounds like con rod knock! :(
I take it that the engine was oil tight still?
Strange it knackered a bottom bearing. They're pretty hardy old engines. How many miles did it have on it when you bought it ?
Around 89,000km when I bought it in 2016 and when the engine went it only had around 116,000km I think!
