- Billingham
- Karl
- E50
- North East
If you have an E51 Elgrand with the built in Sat Nav option, the clock is set by the GPS system in Japan and the clock will show Japanese local time. This is not an easy thing to change, and can be quite involved, but thanks to @Elgrandonaut, a how to guide on setting the time is now available! (Photo for proof)
The guide for doing this can be found here --> https://forum.elgrandoc.uk/threads/...local-time-Elgrand-e51-with-navigation.16807/
The other method to change the time is to replace the clock display itself, which you can find a how to guide on again here --> https://forum.elgrandoc.uk/threads/internal-clock-2002-e51-highway-star.622/
This does not affect the non-GPS models as far as I am aware as they have buttons that you can use to change the time. At the end of the day, if there are no buttons on the clock to change Hours/Minutes, then you will need to use the guide above to replace... or just learn to take 9 hours off for UK time.
