frequently_asked_questions_faqs
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
frequently_asked_questions_faqs [2021/08/22 20:52] – karl | frequently_asked_questions_faqs [2021/09/22 16:46] (current) – karl | ||
Line 10: | Line 10: | ||
This issue has been the cause of much controversy over the years. Please note that we as a club can only recommend a course of action. It is up to you, the individual if you would like to take the advice or ignore it. | This issue has been the cause of much controversy over the years. Please note that we as a club can only recommend a course of action. It is up to you, the individual if you would like to take the advice or ignore it. | ||
- | The E51 has what is known as a Quad-Cat system. This means that there are 4 catalytic converters in total. Two for Bank 1 of exhaust manifold | + | The E51 has what is known as a Quad-Cat system. This means that there are 4 catalytic converters in total. Two for Bank 1 of the V6 engine, and then another two for Bank 2. This applies to both the VQ25 2.5L and VQ35 3.5L engines. |
- | The issue from this system is that over time the first catalytic converters from each bank can deteriorate over time and can break down. The debris from the broken ceramic material then created | + | The issue from this system is that over time the first catalytic converters from each bank can deteriorate over time and can break down. The debris from the broken ceramic material then create |
Some owners have luckily had warning signs which allowed them to react and fix the issue before the engine died. These symptoms can range from rattling sounds in the exhaust area (under the cockpit), drop in revs, low power etc. | Some owners have luckily had warning signs which allowed them to react and fix the issue before the engine died. These symptoms can range from rattling sounds in the exhaust area (under the cockpit), drop in revs, low power etc. | ||
Line 36: | Line 36: | ||
=====General FAQ====== | =====General FAQ====== | ||
+ | ====Underseal==== | ||
+ | All Elgrand' | ||
+ | Depending on where you live in the world, your country may salt roads in winter to help with ice. In the UK, for example, gritters are typically from around November through to February each year depending on weather conditions. If your roads are salted, and you do not underseal your JDM import, the salt from the road will spray up and will corrode any unprotected metal surfaces that it lands on. | ||
+ | Undersealing is the process of adding a barrier to the underbody of your vehicle to protect the chassis, components and body work from salt damage. This will help to prevent rust appearing on your car and allow you more years of trouble free motoring. | ||
+ | There are various types of undersealing systems. From cheap annual jobs, to more expensive long life applications. The method you choose is up to you. You can research the various methods and select the best that fits both you and your budget. But it is important that you do this. Do not leave your JDM vehicle unprotected from salty roads. | ||
====E10 Fuel (UK)==== | ====E10 Fuel (UK)==== | ||
The standard of unleaded fuel in the UK is changing in 2020. E10 (10% ethanol) unleaded is being introduced as the standard unleaded fuel to help combat emissions. | The standard of unleaded fuel in the UK is changing in 2020. E10 (10% ethanol) unleaded is being introduced as the standard unleaded fuel to help combat emissions. |
frequently_asked_questions_faqs.txt · Last modified: 2021/09/22 16:46 by karl
