e51
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
e51 [2022/08/15 18:18] – [Series 1 '02-'04] elementian | e51 [2022/11/27 02:38] (current) – elementian | ||
Line 68: | Line 68: | ||
**Dipped beam**:\\ | **Dipped beam**:\\ | ||
Stock bulb D2R.\\ | Stock bulb D2R.\\ | ||
**Main Beam**:\\ | **Main Beam**:\\ | ||
Stock bulb HB3 or 9005.\\ | Stock bulb HB3 or 9005.\\ | ||
**Side light**:\\ | **Side light**:\\ | ||
Stock bulb 501.\\ | Stock bulb 501.\\ | ||
LED type T10.\\ | LED type T10.\\ | ||
**Indicator**: | **Indicator**: | ||
Stock bulb 585 or WY21W.\\ | Stock bulb 585 or WY21W.\\ | ||
**Fog Light**:\\ | **Fog Light**:\\ | ||
===Headlights Halogen type=== | ===Headlights Halogen type=== | ||
Line 100: | Line 92: | ||
LED type T10 or T15 for extra lumens.\\ | LED type T10 or T15 for extra lumens.\\ | ||
**Brake light**:\\ | **Brake light**:\\ | ||
Stock bulb 7443.\\ | Stock bulb 7443.\\ | ||
LED type T20.\\ | LED type T20.\\ | ||
**Reverse light**:\\ | **Reverse light**:\\ | ||
**Fog Light**: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | **Fog Light**: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | ||
Line 139: | Line 128: | ||
Fog Light: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | Fog Light: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | ||
+ | =====Wiper Blades===== | ||
+ | ===Front Driver side=== | ||
+ | 26" (660mm).\\ | ||
+ | Bosch AR26U\\ | ||
+ | Or\\ | ||
+ | Denso DUR-065R.\\ | ||
+ | ===Front Passenger side=== | ||
+ | 16" (400mm).\\ | ||
+ | Bosch AR16U\\ | ||
+ | Or\\ | ||
+ | Denso DU-040R.\\ | ||
+ | ===Rear wiper blade=== | ||
+ | Rear blade is a special blade 14" (350mm).\\ | ||
+ | Bosch H354\\ | ||
+ | Or\\ | ||
+ | Denso DRA-035\\ |
e51.txt · Last modified: 2022/11/27 02:38 by elementian
