e50
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
e50 [2021/08/22 16:42] – karl | e50 [2021/08/22 19:36] – karl | ||
Line 1: | Line 1: | ||
Here you will find all the basic technical specs for the Nissan Elgrand E50. | Here you will find all the basic technical specs for the Nissan Elgrand E50. | ||
+ | All specifications given are for STANDARD vehicles. Any aftermarket parts may have different specifications. | ||
+ | For aftermarket parts, please check with the supplier. If unknown, you may need to investigate, | ||
+ | ===Chassis Codes (VIN number)=== | ||
+ | You will find the chassis number of your Elgrand either in you Log Book or etched into the bulk head of your E50. Open the bonnet, and look towards the back of the engine above the battery/ | ||
+ | The first 2 letters signify the engine variant: | ||
+ | AL = VG33 3.3l V6 Petrol | ||
+ | AV = QD32 3.2l I4 Turbo Diesel | ||
+ | AT = ZD30 3.0l I4 Neo Turbo Diesel | ||
+ | AP = VQ35 3.5l V6 Petrol | ||
+ | If the chassis code then contains a " | ||
+ | The last two characters of the first part of the chassis code are E50, signifying you have an E50 model Elgrand. | ||
+ | For example APWE50 is a VQ35 4WD model E50. | ||
+ | The last 6 digits (after a hyphen) is the sequential number of your model as it rolled out the factory. | ||
+ | The complete chassis number is the unique identifier for your car. If you need to contact Nissan directly, or some motor factors when looking for parts, will require this number to ensure you get the correct parts/ | ||
=====Engine Specs===== | =====Engine Specs===== | ||
Line 43: | Line 65: | ||
Gearbox Oil Capacity:\\ | Gearbox Oil Capacity:\\ | ||
DIff Oil Capacity:\\ | DIff Oil Capacity:\\ | ||
+ | =====Bulbs===== | ||
+ | ====Pre-Facelift (' | ||
+ | ===Headlights=== | ||
+ | Main Beam:\\ | ||
+ | Side light:\\ | ||
+ | Indicator: | ||
+ | Fog Light:\\ | ||
+ | ===Tail lights=== | ||
+ | Brake light:\\ | ||
+ | Reverse light:\\ | ||
+ | Fog Light: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | ||
+ | ====Facelift (' | ||
+ | Indicator: | ||
+ | High-Level brake light:\\ | ||
+ | Indicator: | ||
e50.txt · Last modified: 2021/08/22 20:00 by karl
