e50
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
e50 [2021/08/22 16:39] – karl | e50 [2021/08/22 19:36] – karl | ||
Line 1: | Line 1: | ||
Here you will find all the basic technical specs for the Nissan Elgrand E50. | Here you will find all the basic technical specs for the Nissan Elgrand E50. | ||
+ | All specifications given are for STANDARD vehicles. Any aftermarket parts may have different specifications. | ||
+ | For aftermarket parts, please check with the supplier. If unknown, you may need to investigate, | ||
- | ===== QD32 3.2l I4 Turbo Diesel E50 ===== | + | ===Chassis Codes (VIN number)=== |
- | ==== Engine Specs ==== | + | |
+ | You will find the chassis number of your Elgrand either in you Log Book or etched into the bulk head of your E50. Open the bonnet, and look towards the back of the engine above the battery/ | ||
+ | The first 2 letters signify the engine variant: | ||
+ | AL = VG33 3.3l V6 Petrol | ||
+ | AV = QD32 3.2l I4 Turbo Diesel | ||
+ | AT = ZD30 3.0l I4 Neo Turbo Diesel | ||
+ | AP = VQ35 3.5l V6 Petrol | ||
+ | If the chassis code then contains a " | ||
+ | The last two characters of the first part of the chassis code are E50, signifying you have an E50 model Elgrand. | ||
+ | For example APWE50 is a VQ35 4WD model E50. | ||
+ | The last 6 digits (after a hyphen) is the sequential number of your model as it rolled out the factory. | ||
+ | The complete chassis number is the unique identifier for your car. If you need to contact Nissan directly, or some motor factors when looking for parts, will require this number to ensure you get the correct parts/ | ||
+ | =====Engine Specs===== | ||
+ | ==== QD32 3.2l I4 Turbo Diesel E50 ==== | ||
Power: 150 PS (110 kW; 148 bhp) @ 3600 rpm\\ | Power: 150 PS (110 kW; 148 bhp) @ 3600 rpm\\ | ||
Line 10: | Line 32: | ||
- | ===== VG33 3.3l V6 Petrol | + | ==== VG33 3.3l V6 Petrol ==== |
Power: 172 PS (127 kW; 170 bhp) @4800 rpm\\ | Power: 172 PS (127 kW; 170 bhp) @4800 rpm\\ | ||
Line 18: | Line 40: | ||
- | ===== ZD30 3.0l I4 Neo Turbo Diesel | + | ==== ZD30 3.0l I4 Neo Turbo Diesel ==== |
Power: 170 PS (125kW; 168bhp) @3600 rpm\\ | Power: 170 PS (125kW; 168bhp) @3600 rpm\\ | ||
Line 26: | Line 48: | ||
- | ===== VQ35 3.5l V6 Petrol | + | ==== VQ35 3.5l V6 Petrol ==== |
Power: 243 PS (179 Kw; 240bhp) @??? rpm\\ | Power: 243 PS (179 Kw; 240bhp) @??? rpm\\ | ||
Line 32: | Line 54: | ||
Engine Oil Type: 5w30 OR 5w40 Fully Synthetic\\ | Engine Oil Type: 5w30 OR 5w40 Fully Synthetic\\ | ||
Engine Oil Capacity: 4.9 litres (with oil filter)\\ | Engine Oil Capacity: 4.9 litres (with oil filter)\\ | ||
+ | =====Transmission Specs===== | ||
+ | ====RWD==== | ||
+ | Gearbox Oil Type:\\ | ||
+ | Gearbox Oil Capacity:\\ | ||
+ | DIff Oil Capacity:\\ | ||
+ | ====AWD==== | ||
+ | =====Bulbs===== | ||
+ | ====Pre-Facelift (' | ||
+ | ===Headlights=== | ||
+ | Main Beam:\\ | ||
+ | Side light:\\ | ||
+ | Indicator: | ||
+ | Fog Light:\\ | ||
+ | ===Tail lights=== | ||
+ | Brake light:\\ | ||
+ | Reverse light:\\ | ||
+ | Fog Light: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | ||
+ | ====Facelift (' | ||
+ | Indicator: | ||
+ | High-Level brake light:\\ | ||
+ | Indicator: | ||
e50.txt · Last modified: 2021/08/22 20:00 by karl
