e50
Next revision | Previous revisionNext revisionBoth sides next revision | ||
e50 [2021/08/22 16:21] – created karl | e50 [2021/08/22 16:47] – karl | ||
Line 1: | Line 1: | ||
- | ===== QD32 3.2l I4 Turbo Diesel | + | Here you will find all the basic technical specs for the Nissan Elgrand |
+ | All specifications given are for STANDARD vehicles. Any aftermarket parts may have different specifications. | ||
+ | For aftermarket parts, please check with the supplier. If unknown, you may need to investigate, | ||
- | Power 150 PS (110 kW; 148 bhp) @ 3600 rpm | + | =====Engine Specs===== |
- | Torque 34 kg⋅m (330 N⋅m; 250 lb⋅ft) @ 2000 rpm | + | ==== QD32 3.2l I4 Turbo Diesel E50 ==== |
+ | Power: 150 PS (110 kW; 148 bhp) @ 3600 rpm\\ | ||
+ | Torque: 34 kg⋅m (330 N⋅m; 250 lb⋅ft) @ 2000 rpm\\ | ||
+ | Engine Oil Type: 5w40 Fully Synthetic\\ | ||
+ | Engine Oil Capacity: 7 Litres (with filter)\\ | ||
- | ===== VG33 3.3l V6 Petrol ===== | ||
- | Power 172 PS (127 kW; 170 bhp) @4800 rpm | + | ==== VG33 3.3l V6 Petrol ==== |
- | Torque 28 kg⋅m (274 N⋅m; 202lb⋅ft) @2800 rpm | + | |
+ | Power: 172 PS (127 kW; 170 bhp) @4800 rpm\\ | ||
+ | Torque: 28 kg⋅m (274 N⋅m; 202lb⋅ft) @2800 rpm\\ | ||
+ | Engine Oil Type:\\ | ||
+ | Engine Oil Capacity:\\ | ||
- | ===== ZD30 3.0l I4 Neo Turbo Diesel ===== | ||
- | Power 170 PS (125kW; 168bhp) @3600 rpm | + | ==== ZD30 3.0l I4 Neo Turbo Diesel ==== |
- | Torque 36 kg⋅m (353N⋅m; 260lb⋅ft) @ 1800rpm | + | |
+ | Power: 170 PS (125kW; 168bhp) @3600 rpm\\ | ||
+ | Torque: 36 kg⋅m (353N⋅m; 260lb⋅ft) @ 1800rpm\\ | ||
- | ===== VQ35 3.5l V6 Petrol ===== | ||
- | Power 243 PS (179 Kw; 240bhp) @??? rpm | + | ==== VQ35 3.5l V6 Petrol ==== |
- | Torque 36 kg⋅m (353N⋅m, 260lb⋅ft) @???rpm | + | |
+ | Power: 243 PS (179 Kw; 240bhp) @??? rpm\\ | ||
+ | Torque: 36 kg⋅m (353N⋅m, 260lb⋅ft) @???rpm\\ | ||
+ | Engine Oil Type: 5w30 OR 5w40 Fully Synthetic\\ | ||
+ | Engine Oil Capacity: 4.9 litres (with oil filter)\\ | ||
+ | =====Transmission Specs===== | ||
+ | ====RWD==== | ||
+ | Gearbox Oil Type:\\ | ||
+ | Gearbox Oil Capacity: | ||
+ | DIff Oil Capacity: | ||
+ | ====AWD==== | ||
+ | =====Bulbs===== | ||
+ | ====Pre-Facelift (' | ||
+ | ===Headlights=== | ||
+ | Main Beam:\\ | ||
+ | Side light:\\ | ||
+ | Indicator: | ||
+ | Fog Light:\\ | ||
+ | ===Tail lights=== | ||
+ | Brake light:\\ | ||
+ | Reverse light:\\ | ||
+ | Fog Light: NOT STANDARD PART (NOT REQUIRED IN JAPAN) - YOU WILL HAVE TO CHECK YOUR OWN SET UP\\ | ||
+ | ====Facelift (' | ||
+ | Indicator: | ||
+ | High-Level brake light:\\ | ||
+ | Indicator: | ||
e50.txt · Last modified: 2021/08/22 20:00 by karl
